Displays RIPng global configuration and runtime information.
N/A.
None.
The following command displays RIPng global configuration and runtime information:
show ripng
The following is sample output from this command:
RIPng Routing : Disabled Aggregation : Disabled Update Interval : 30 Route Timeout : 180 Garbage Timeout : 120 Originate Default: Disabled Sys Import-Policy: None Redistribute: Protocol Status Cost Tag Policy ----------------------------------------------------------- Direct Disabled 0 0 none Static Disabled 0 0 none Ospfv3-intra Disabled 0 0 none Ospfv3-inter Disabled 0 0 none Ospfv3-extern1 Disabled 0 0 none Ospfv3-extern2 Disabled 0 0 none IsisL1 Disabled 0 0 none IsisL2 Disabled 0 0 none IsisL1Ext Disabled 0 0 none IsisL2Ext Disabled 0 0 none bgp Disabled 0 0 none
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
